sorry no pictures but i made mine out of 3/4 in plywood for the base and top,used a 4by 4 for the pillar.i measured the top plate so it was the same size as my speaker base,made the bottom same size as the top.used some screws and attached the speaker to the top plate, painted it all glossy black.just figure out how high you want the top of your speakers.don't forget to add the 1and 1/2 inches the thickness of your plywood and there you go.hope this helps.
