Results 1 to 4 of 4
    Forum Regular 46minaudio's Avatar
    NC
    Bravox 3.5 & Dayton Xover Help
    I bought some Bravox 3.5 in drivers as a buyout several months ago.
    http://www.partsexpress.com/pe/showd...number=269-685
    I am thinking about buying these tweeters that are on sale.
    http://www.partsexpress.com/pe/showd...number=275-070
    I can go with a 6liter closed box that will have a f3 of about 125hz.or a vented 6 liter tuned to 85hz with a f3 of 71 hz..This is with 2 drivers wired in parallel.To my understanding this should show a 6 ohm load and a 6db spl boost..This should bring both woofers and tweeter to 89DBs.These calculations came from winisd..I am new at this and have built 2 or 3 pairs using buy ot nsbs and such..I was thinking 2 order butterworth at 2500..Any help on box size, Xover suggestions ,and mismatches would be helpful Thanks Lee.
    DIY Dude poneal's Avatar
    Sep 2003
    TX, USA
    Just took a look and
    these drivers are going to take a lot of work on the crossover design to take out those peaks and dips. I'm not an expert on xover design but you may post this message at PE tech talk and someone may have a design already. Looks like the 3.5" driver is more suited to midrange use say from 500hz on up to the tweeter crossover than for woofer duty. You many be able to get some decent computer speakers out of them with a proper crossover design. Vented will get you a little lower but the peaks and dips are even worse using vented over sealed. I'm sure this is not what you wanted to hear but if your looking at making a decent two way then you need a bigger woofer (say 6.5" or min of 5.5").
    Sep 2003
    TX, USA
    found you a link to an mtm design
    NC
    Quote Originally Posted by poneal
    Thanks I had seen this but kinda wanted to come up with somthing using the Dayton tweeter...Xover and TB tweeters would be over $ 75.A little high considering I have $3 each in the drivers..
    Thanks for the help...
  1. 15 Dayton Titanic MKIII subwoofer kit review
    By Sealed in forum The Audio Lab, Tweaks, Mods, DIY
    Last Post: 01-31-2005, 06:53 AM
  2. Dayton Audio Interconnects
    By nightflier in forum Cables
    Last Post: 09-20-2004, 08:37 AM
  3. Replies: 3
    Last Post: 07-01-2004, 02:38 AM
  4. Better Sub? Velodyne, HSU, or Dayton?
    By twwesn in forum Speakers
    Last Post: 03-09-2004, 12:56 PM
  5. Dayton In-Walls
    By DrJeff in forum Home Theater/Video
    Last Post: 12-15-2003, 09:43 AM
