Results 1 to 3 of 3
    Jul 2003
    B&W DM600 Woofer Replacement Question
    Hello:
    I have a pair of B&W DM600s which my wife destroyed due to her limited knowledge of "clipping". So, as a quick fix, I put a couple of Radio Shack 6 1/2 inch woofers in them and they sound like crap (of course). Thanks to the plummeting US dollar, replacement woofers are about $100.00 each from B&W.
    So, here's my question: what other alternative do I have for replacement woofers? Am I pretty much stuck with the B&W replacement parts due to the crossover and the tweeter combination? Are there decent drivers I could put in them to get good sound without spending $200.00?
    Thanks,
    B. Rose
    Feb 2005
    Well since you already spend some money on the 602, they are quite decent. I would suggest reparing them 100%. I would replace them original parts.
    -Florian
    May 2003
    NY
    We have some great DIY guys that can point you where to go
    Quote Originally Posted by cbrose
    Hello:
    Thanks,
    B. Rose
    That's why I'm posting this thread to the DIY forum.
    From whay I've heard and seen, you should be able to replace those woofers for a lot less.
    Audio;
    Ming Da MC34-AB 75wpc
    PS Audio 4.5 preamp,
  1. Replacement woofer for Infinity RS sub
    By phillyguy in forum Speakers
    Last Post: 12-31-2003, 02:30 PM
