Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 26 to 50 of 119
  1. #26
    France
    You can probably go with either. As you say, if they aren't aligned they might help with standing waves. To what extent I'm not sure...
  2. #27
    Can an egg have standing waves?
  3. #28
    You got that thing built yet?
  4. #29
    Smarty pants!
    Any ideas or commrnts? (jokes not withstanding)
  5. #30
    No, not really. Think you've got enough info to go ahead. If it doesn't work well, making a box is cheap and easy, so low-risk here. You've got far more patience than I do with the amount of cutting and sanding you're looking at. But pictures of this will spread all over the world, I'm sure.
  6. #31
    Suspended atomicAdam's Avatar
    Apr 2008
    Oaktown!
    I could use someone to hold my wood while I cut it.
    Your wife doesn't have issues with another dude holding your 'wood'?
  7. #32
    Or having it cut.....
  8. #33
    Apr 2008
    Oaktown!
    At this point you might be too old to use it, I don't know? So having it cut might be some form of stimulation..
    Anyways - I wanna see photos (of the egg)!
  9. #34
    May 2008
    I agree with the extra bracing. It's not so much that you need it and would have to add it later, with the shape you have and the thick walls you don't really "need" bracing at all. But I would always do bracing as it's the most efficient way to get a stiff box. With bass it's all about stiffness and there is never too much.
    There is no need to "break up sound waves." Design your bracing for maximum stiffness and you should be fine. With a sealed box, it's not so much what goes on inside the box, but what gets out. There are two ways to get out of the box:
    1. Through vibrating the enclosure - this is what most worry about and it's important, but not as much as
    2. Re-radiating through the cone itself - this is controlled by the damping of the driver
    The second is a much overlooked problem, described here:
    http://www.rythmikaudio.com/re-radiation.html
    Consider this. You have very stiff and thick walls - 2" right? They will be as solid as you can make them. Now you have an 18" light weight cone that is designed to be compliant so that it can efficiently create bass. Which do you think provides the easier path for sound to get out of the box? Here we are not talking about transmission so much as the sound pressure waves from inside the box placing dynamic pressure on the cone, just like an active driver will cause passive radiators to move. It is the same except the active driver has an electric motor which resists interference. The driver Qts indicates the ability of the driver to reject this influence.
  10. #35
    Quote Originally Posted by paulspencer
    Thanks Paul. All great info.
    I think the shape of the "box" in this case should help cut down on the re-radiating factor. What do you think there?
    I also plan on adding 2 inch Mineral Wool inside. The driver manufacturer suggests a half fill.
    Thanks for the link. I guess all those curved speakers (IE:B&W) are not just for looks.
    Here are the specs on the driving I will be using.
    Fs: 17.4 Hz
    Le: 4.0mH
    Re: 3.8 Ohms (Voice Coils wired in series)
    Qms: 3.62
    Qes: .42
    Qts: 0.37
    Mms: 525g
    Cms: 0.16 mm/N
    Vas: 313L
    Sd: 1182 cm^2
    BL: 22.9
    X-max: 32mm
    Pmax: 1500W
    SPL: 87.8 db/1W/1M
  11. #36
    OK, I have been on vacation for a bit so I haven't been posting my progress here. On the bright side, I was able to get a bit done. Let's start it off with a pic of the scrap wood. What a frickin' mess. It's a good thing that honey was away for two weeks.
  12. #37
    Here are the good rings that will be put to work.
  13. #38
    Inventory had to be taken.
  14. #39
    A view of some of the stuffing, and one of the braces.
  15. #40
    Half an egg is better than none?
  16. #41
    Finally it's taking shape.
  17. #42
    To give you an idea of the size, that's a Honda CRV behind it.
  18. #43
    But I left room for the binding posts.
  19. #44
    Another view of the bracing.
  20. #45
    It looks good sanded down.
  21. #46
    After the primer, I stained it china red. It looks more orange than red to me. I put a coating of red oak after this but it hasn't dried yet.
  22. #47
    Wow!! Very impressive, GM.
  23. #48
    Thanks Feanor. I know that you are or have been a bit of a DIYer. I'm glad you like it.
    The base will end up black. I was thinking that with a 9&1/2 month old in the house, it's only a matter of time before something gets shoved under the driver. So I'm putting a netting like material around the base. It's made of a tough plastic so it should keep out the unwanted objects.
  24. #49
    GMichael I am impressed. Very nice work. Wow you can do other things with your hands, I mean besides holding your beautiful daughter. I am anxious to read your report on how it sounds.
    I think you have created Modern Art for the Chicago Art Institute.
