NAD 2200 Power Envelope - HELP!!!!
Hey guys....I just found a NAD 2200 Power Envelope in the trash the other day and at first it appeared to only have a blow fuse. So i replaced this fuse and it worked fine for a few minutes...but then one of the channels went off and the other one a bit later. I noticed that when i tapped the two relays near the input/output jacks in the rear, it would begin playing and then stopped within a second or just crackle when i tapped it. Also, when the amp is turned off, the speakers make an extremely loud pop. I am not much of a pro on audio but this amp sounded great when it first worked and i would like to get it working again. I was told by one person that I would just need to replace the relays w/ some simular audio quality ones. I have soldering skills so that's no problem, but i dont want to put out the money without knowing if something else could also be the problem. If it is the relays then which relays would be the best and where can i get them? Thanks:confused:
NAD 2200 experiencing crackle on one channel
Hi all,
Since I could find no better place with so many experienced enthusiasts as well as a timely thread about the trusty NAD 2200's, I thought I might list my own troubles.
I have a set of monoblocked NAD 2200's (they're awesome!). However, recently one of the amps has started to suffer from random crackles and loud hissing at times, which miraculously disappears for sometime (even a few days). Is this because of the relays being poorly soldered as experienced by 'maxxoholic420'?
I did notice that tinkering with the binding post at the back offers some temporary relief at times. I'm thinking perhaps even the solder on the binding post (which is coupled directly to the PCB) might be in question.
Being a bit of a DIY fella who can weild a soldering iron, I might as well give the old powerhouse a shot at revival before throwing in the towel. Professional repairs are an expensive nuisane in England, therefore, any help and suggestions are welcome.
Thanks.
