Results 1 to 14 of 14
    Suspended BallinWithNash's Avatar
    May 2009
    Mesa, AZ
    My Marantz 2240 is slowly dieing!
    Alright guys my Marantz 2240 won't play music out of the left speaker before it wouldn't play at low volumes but now it just won't play at all. Any ideas on a fix ... if the fix isn't easy and somewhat cheap I'll probably end up getting rid of it
    Dallas, TX
    Pots need cleaning? Try switching and turning everything several times and see if that makes a difference.
    Jul 2006
    get yourself some deoxit, clean the darn thing...
    Life is music!
    Mcintosh MA6400 Integrated
    Double Advent speakers
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-103 in midas body
    *Denon DL-304
    *Lehmann audio black cube SE
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Sonic link Black earth IC's
    Siltech MXT New york IC's
    Kimber 4VS speakercable
    Furutech powercord and plugs.
    I'm a happy 20 year old...
    May 2009
    Mesa, AZ
    Alright so what exactly do I clean? I mean there is a million different things in there haha I know how to take it apart I just need to know what I clean thank you
    Philadelphia, PA
    You spray the deoxit into the volume and balance controls and rotate them vigorously. If they are dirty and or corroded the rotation and deoxit will clean them.
    This must be done from the inside.
    Maybe ask Nash if he can do it for you.
    May 2009
    Mesa, AZ
    Ok well Home Depot didn't have any deoxit (i didn't think they would) but they had CRC Electrical Grade QD Contact Cleaner ... will this work?
    Any contact cleaner will work. It's like any other product, Deoxit is just a name of a brand.
    May 2009
    Mesa, AZ
    Ok thanks guys
    May 2009
    Mesa, AZ
    Aright THANK YOU SO MUCH it still cuts out at low volumes but if you play it a little louder no problem ... thank you guys should I spray a little more and do you think that will fix the low volume problem?
    Quote Originally Posted by BallinWithNash
    Yes. Spray alot into it and let soak. Then turn the knob or switch about 30 - 50 times in the full range of motion.
    May 2009
    Mesa, AZ
    Okay poppa i did what you said and now its back to the way it was it only plays out of the left speaker unless I have the mono button pushed in (so its on) ....so I took it back apart then plugged it in and it works??? so if I have the wood covering it apparently doesn't work? any thoughts?
    May 2009
    Mesa, AZ
    Okay so as long as I leave the wood casing off it works but if I put it on well it's shaky ... so ill just leave it off ... thanks guys!
    Feb 2009
    Rochester, NY
    Sounds like something is overheating. Perhaps the output transistors on the bad channel could be on their way out.
