Old tube receiver connection symbols?
I recently acquired a Martel/Rotel FAX-150c tube receiver made in the 1960's. Stamped on the rear chassis beneath the speaker screw connections are the following:
right 0 8 0 8 left
So is the 0 the positive or is the 8 the positive?
Under the FM/AM group the following is stamped on the chassis beneath the screw connections:
FM G AM
Would I use the G ( only ground I see ) to connect the phono ground wire?
The phono inputs are marked MAG and X-TAL so the MAG would refer to a magnetic cart but what is X-TAL?
