Yamaha Problem - HTY-760 Set Up Problem - Intellibeam
Hi Guys,
I am really frustrated, today I have recived my Yamaha HTY-760, since then I am trying to set it up without sucess, here at it happens:
1st - Cant see the HTY-760 display menu on the TV, no matter which connection I will choose 1,2,3c whatver It will never display the menu. If I connect my macbook to the tv I will have no problems whatsoever.
2nd - MOST IMPORTANT. Everytme I will run the auto set up with the intellibeam pluged in I always get the same error E-6 (Volume level is lower than expected. Please check the MIC position\connection and re-try)
Could the intellibeam mic be broken? I have tried everything so far: to place the mic closer, away from the unit and so on and so on.
What can I do more? Can you please advise me, your help will be very much appreciated. I want to try everything I can before posting back this item to Pixmania, it will be a huge pain to post it and have to wait for some resolution from them.
Cheers,
Henrique
