On-wall Paradigm Monitor 5 questions (or any on-wall for that matter)...
How are they attached to the wall? Is there any way to angle them (with my plasma, the center will be quite a bit lower than the ear so I'd want to angle it upward)...
08-14-2005, 10:10 PM
N. Abstentia
Wouldn't the Monitor 5's be a bit large for wall mounting?
08-15-2005, 03:19 AM
kexodusc
They On-Wall Monitor 5's are in smaller cabinets than the normal Monitor 5's, but sound pretty much the same from 100 Hz up...they're a bit thinner below that IMO, a price you'll have to pay for wall mounted speakers no matter the cost. Still, a good buy.
They have a mounting bracket, I don't belive you can angle them up or down, just side to side, and not much.
08-15-2005, 09:06 AM
pdawg17
Getting these, of course, is labeled under the ole "compromise with the wife" heading...I have Studio 20's but recently got a plasma that is wall-mounted so she thinks to utilize the extra space we should have wall-mounts...my sub will take anything under 90Hz so hopefully they will sound fine...
