Wall Mount Bracket
Where can I buy bookshelf wall-mount bracket ?
Crutchfield has these B-tech wall mounts, which is what I use. They are rated for up to 55lbs and are built exceedingly well. A nice feature is that they hold your speaker in place through compression, kind of like a vise grip, and you therefore don't have to drill into your speakers. Foam pads are supplied which stick to the side arms and grip your speaker. You can also change both the vertical and horizontal planes very easily.
Hope this helps.
http://akamaipix.crutchfield.com/pro...21bt77s-f.jpeg
