Subwoofer Placement and Volume Adjustment
I just recently purchased a Polk PSW10 subwoofer and am trying to figure out the best place to position it. Currently I have it in the corner. Also what would be the best volume setting?
The "best" place to place...
...a sub might not be the most aesthetically pleasing. This method won't work for everyone, but it did for a friend of mine...
Put the sub where you normally sit - the "sweet spot". Crawl on the ground a figure out where the bass sounds best to you... usually, the loudest. THAT is the spot for the sub. Normally, without trying this, I would not have believed it. In my friend's livingroom, it was the best spot. Didn't land too far from a tri-corner, but not exactly where I would have started!
Something to try,
Jimmy
