Hello, everyone-
I have a Def Tech PS80 subwoofer and previously hooked it up through my older Sony receiver via a high level speaker wire connection. I recently upgraded my receiver to a Yamaha HTR5760 and have a subwoofer out.
I bought a sub cable and hooked it up to my subwoofer LFE input. I heard that I can get a y-connector and hook the cable into both the left and right of the Low Level In on my sub. Is that something I should do? I checked the manual and the Low Level In (L/R) is shown used through an amp of some sort, but I heard I should use the Y with the L/R input.
Thanks.
Eric
