Speakers for small room / 80W per channel receiver?
Just bought a 50 inch Panasonic plama. Have a Yamaha HTR-5650 receiver (80 watts per channel - 6 channels). In the market for a speaker system. Small square room - about 10 x 12 feet. Want crisp, strong theater sound, primarily for movies. Budget is $1000-1200, but not sure I need to spend that given my 80W per channel / small room setup. Have been looking at the Definitive ProCinema 60 and 80 and the Orb Mod1 and Mod2. Specifically, I have 3 questions:
1. Assuming I was to go with the ProCinema or the Orbs, given my setup, is there any added benefit to the higher end systems (the ProCinema 80 or the Mod2), or would my sound basically be the same with the lower end (ProCinema 60 or Mod1)?
2. As between the ProCinema and the Orb, which would you go with?
3. Should I be considering any other speaker systems for my setup? In other words, what else would you recommend?
THANKS! Mike
