Results 1 to 4 of 4
    May 2006
    Speaker surround replacement problem.
    Hello.
    I have a pair of vintage Advent Loudspeakers..
    http://spiker611.servehttp.com/wooferout.jpg
    You may be able to see that the woofer surrounds are pretty.. well.. gone..
    I want to replace them, but you see that big wooden ring? For some reason, its glued onto the metal casing of the speaker, so that the speaker surround doesnt have to go so far. Well, to replace the surround, I need to glue the new one to the bottom of that ring..
    does anyone know how to remove this, or if I should just try and do it with the ring still on?
    Thank you!
    Forum Regular PAT.P's Avatar
    Oct 2004
    ont ,canada
    Just go to www.simplyspeakers.com At the left side go to "Do-it-Yourself" than "Speaker Repair Instuction" .Dont try to remove the wooden ring (they break )Cheers!
    May 2006
    Oh, thank you so much!
    Oct 2004
    ont ,canada
    Quote Originally Posted by spiker611
    Your welcome.I have the same pair to be redone also when I have the time.
