Results 1 to 7 of 7
    Jan 2006
    Rochester, NY
    5.1 Suggestion - Infinity, Klipsch, Other?
    I am looking for a suggestion on a 5.1 system for my parents ($400-$600 range). Before I go store jumping this w/e, I wanted to get an idea of what I should be looking for. So, some I am considering...
    Infinity TSS-750
    Infinity TSS-450
    Athena Micra 6
    Polk RM6700
    Polk RM6750
    Polk RM6800
    Klipsch Synergy Quintet II
    These speakers will be mated to a Harman Kardon AVR-335.
    Thanks in advance!
    Did you already buy something? If I had to choose from what you listed, my first choice would be the Polk and then maybe the Athena but I haven't heard that exact package. Depending on what your parents are using for electronics they might find the Klipsch or Infinity too bright. One advantage of the Klipsch is it would be easy to drive if they have a low power receiver, the draw back is the limited dispersion from the horns they use. I haven't heard the TSS either but the last Infinity I auditioned was terribly unbalanced. It was like the tweeter player much louder than the woofer. I wish I could remember the model, maybe an Alpha something. Acoustic Energy makes good sounding budget priced speakers if you see them in your area.
    try DefinitiveTech
    much better than Infinity and Klipsch
    Pioneer VSX-AX3 Receiver
    Pioneer Dv-668 Dvd(Ecosse Composer MKII inter.)
    Infocus Screenplay 4805(AR Pro II Component)
    B&W 602 S3 Fronts(Monster THX)
    B&W CLR 60 Center
    B&W CDM-SNT Surr.
    Denon PMA-1500 MK II int. amp.
    Definitive Tech SuperCube II SW
    H/K HD970(Ecosse Composer MKII inter.)
    Marantz CD5001(AR PRO II inter.)
    Marantz PM-17MKII M
    Kef IQ3(Ecosse Cs2.3 wire)
    Jan 2006
    ottawa, ontario
    don't go bashing other peoples likes, you might consider them a great manufacturer, but kilpsh and infinity a great speaker makers too!!! :P
    he asked
    and i answer so what?
    B&W CLR 60 Center
    B&W CDM-SNT Surr.
    Marantz PM-17MKII M
    Jan 2006
    ottawa, ontario
    well, make a suggestion recommending the other speakers, but don't bash the other companies, have you done direct A/B comparison with the brands mentioned?
    Jan 2006
    Rochester, NY
    I did end up with the Infinity...bought from Harmon direct on eBay at a great price. They arrive tomorrow.
