Speaker Stand Help........
Hello people. I just bought some Athena S.5's package and have the fronts and rears on speaker stands. This works quite well except they slide around on the top plate of the speaker stand. Is there anything I can buy that will fit the top plate of the stand and will stop my fronts/rears from sliding around?? Maybe something that could help with the resonating as well. I know sound deadening material would help with the resonation but what about the speaker still moving around??? I need something that will do both. Would it be wise to use some kind of sticky pads that will stick to both the top plate of the speaker stand and the bottom of the speaker??? Anyways, please let me know if you have any suggestions. Thank you for your time.
