Speaker Cabinet Rebuild question . . .
I was wondering
1) What type of sound-absorbing material specifically should be used inside the cabinet? Is more necessarily better?
2) What specific product should i use to seal the woofer(s) and tweeter(s) to the cabinet? Is there some type of sealing tape or something you are supposed to use in conjunction with the mounting screws?
3) What type of specific glue should be used to glue the cabinet together? Right now i have a bottle of titebond2 premium wood glue which seems like it should work alright but i want to make sure that there isn't a better glue out there i should be using.
4) does anyone have any website links or references that could help me in my cabinet rebuild? Thanks.
