So, what does this mean??? Collapsed sound stage.
I found that my sound stage is collapsed to the right. In other words: The sound stage does not run speaker to speaker, but runs about 2 feet short of the left speaker to the right speaker. I can fix it by pigion toeing in the left speaker a 1/4 of inch more then the right speaker (I'm making a triangle as was recommended on this forum.
I have very long wire runs, probably about 30 ft. I have the receiver in the back of the room and the speakers inthe front. Then the wire runs behind the walls. Finally, I have plug ins for the jacks upfront. The total impedance is about .15 ohms (10 gauge speaker wire).
Is this slight shifted/collapsed sound stage caused by differrent lengths of wire? Or what else might cause it.
Thanks for your help.
Best Regards,
Stan
