Redbeard sees (or hears?) the light!
Originally Posted by Redbeard
I must agree with you and upon futher consideration the Cambridge seems to fit the bill nicely which no other sub can do. Excellent musical reviews, small box, very attractive, deep bass down to 24Hz, full control with remote.
How should I set this up any thougths, problem is I have my tv kiddie cornerd in the living room and the couch against the far wall at a 90 degree angle. Main Speakers are right next to the TV and anlged at 45 anlge toward the main listening area. Room has hardwood floors and a full brickwall fireplace. I don't even know where to begin to set this up? In the past I could not get my old Paradigm PDR-10 to blend well with my Boston VR-M60's, you could always tell where the bass was coming from. Maybe that is because it did not have a phase control?
Glad to see you're coming around, Red. A/V forums are helpful when taken with the proper skepticism and reading between the lines. IOW, sometimes, 50,000 Elvis fans can be wrong. bobhaze said it all pretty well; no need for me to labor the point.
My first thought about localization of bass would be crossover freq. After that, I'm not nearly experienced enough to offer any valuable advice on dealing with room effects or peaks and valleys. (I'm much better at telling you how to spend your money ;) )
As for placement, you could put it in the corner behind the TV, maybe? No, that'd be a tragedy because you couldn't see that beautiful CSW cabinet. BTW, my Newt'n bookshelves are also in the blonde maple and they are GO-geous. But I digress...
IIRC, the P500 comes with a "semi-parametric EQ" (per the CSW web site). That might help some. You might try e-mailing your scenario to someone at CSW, via the link on their site. You could also visit HERE It's a little hive of guys who've drunk the CSW Kool-Aid. There's actually been a pretty active conversation lately about the pros and cons of the P500 vs. the P1000, etc. bobhaze, you might check it out, too, if you're so inclined.
