RMS vs Dynamic Power handling? Does the "dynamic" power mean anything?
Hey all, I am looking at a Klipsch KSW-10 Sub. It says the RMS is only 50 watts, but the dynamic is 225. Is dynamic just another word for peak, aka not really how much power it will put out?
I guess im just wondering how much power this thing will have?
KSW-10 Specifications:
* Frequency response: 29Hz-120Hz±3dB
* Power handling:
FTC Rated Power: 55 watts continuous, 22-125Hz @ = 1% THD
Dynamic Power*: 225 watts @ = 1% THD *Dynamic power indicates the actual power this amplifier will deliver to the woofer under normal operating conditions. While the FTC power rating indicates power available on a continuous, long-term basis, subwoofers do not rely on that type of power. Instead, the amplifier is called upon to deliver large, short-term peaks of power to be able to support the wide dynamics required by today's digital music and movie formats. In addition to the required FTC power rating, we've provided the dynamic power rating as a better indication of the product's true performance.
* Sensitivity: 110dB SPL 1/8 space, 1 meter
* Low pass crossover: Continuously variable from 40-120Hz, 24dB/octave slope above 120Hz
* Woofer: K-1070-K 10" (25.4cm) down-firing fiber-composite cone
* Amplifier: Class A/B discrete MOSFET outputs
* Phase: Switchable 0 or 180 degrees
* Enclosure material: MDF
* Enclosure type: Bass reflex via rear-mounted port
* Inputs: 2) Line level/LFE RCA phono jacks and 2) High level speaker terminals
* Auto power on: 2 Second ON delay, 15 minute OFF delay
* Dimensions: 15.5" (39.37cm) x 13.5" (34.3cm) x 13.5" (34.3cm)
* Weight: 29 lbs. (13.18kg)
* Finishes: Matte-finish Black vinyl
* Voltage: 110/120 VAC/60Hz
* Export voltage: 230 VAC 50/60Hz
* Built from 1998
http://www.wwstereo.com/website/ecom...product=KSW-10
Here is the correct answer of "What is RMS?"
[QUOTE=harley .guy07;309769]Well yes it does. RMS power stands for Rate Mean Square.
RMS means ROOT MEAN SQUARE.
It is the square root of the mean square. In simple terms it is the average running power of any amplifier (as opposed to peak power, AKA "dynamic power")
Dynamic Power standard meaning
Originally Posted by
mlsstl
There is no standard industry definition for "dynamic" power. It means whatever the manufacturer wants it to mean. I discount all such references as marketing jargon of the useless variety.
If you think about it, if any part of the audio spectrum needs "continuous" power, it is in the bass region. I was at church the other day listening to their pipe organ. That beast (about 7,700 pipes - it's in an old cathedral) is capable of putting out some very sustained deep bass frequencies. If that's the music you're trying to reproduce with this sub and 50 watts isn't enough, then their "dynamic" rating is of no help whatsoever.
That said, the subwoofer's 50 watts may well be perfectly adequate depending on the volume level you're trying to achieve. The dynamic rating of 225 watts may only be present for impressing the susceptible. I'd recommend listening to the unit and see if it does what you want done.
Yes, there is a "standard industry definition". Dynamic power is tha same as peak power.
