rear ported for rear surrounds
Will this cause a problem if the rear speakers are rear ported ? can they be wall mounted or do they have to be on stands ? If they do need to be on stands shoot those will be tall ones for sure. ( talking about bookshelfs ) any other suggestions on how to get them up there (the ideal rear listening position). My rears are on unstable stands right now and as you read they are rear ported. what to do ? I dont want to screw in shelves in the walls (rental property) the stands we are currently using are telescopic and can go as high as 4ft with the tweeter at about 4.5 ft ( but not very stable they are leaning against the wall fo extra support)
Thanks
