Quote Originally Posted by modalnomad View Post
Thanks for the info! How did you know the part I found would be an exact fit? If it does I'll probably just do that. The binding post knobs are kind of a pain and I can't really see a cable having a good time hanging out there... I imagine the gold plating helps with conductivity as well?
There is no standardization of jumpers and I suspect the PE jumpers won't fit. But are the Mirage's "knobs" similar to the PE's? These are so-called "5 way" connectors: they are designed accommodate bare wire, soldered wire, pin terminators, spades, or banana plugs. Using 16 ga. wire blackraven recommends, you would ideally terminate the wire with spade connectors, then your speaker cables could then be terminated with banana plugs or possibly spades if the cable and jumber spades can go be attached at the same time.
Opps! I see that theHills suggestion amounts to pretty much what I'm saying.
