Need some subwoofer advice...
I recently bought one of those Athena P300 home audio subs from Best Buy when they had a special promotion going. The sub sounds great, however my main speakers drown it out. I definitely need something with a bigger speaker and more power (probably a 10" would be fine). My main speakers are JBL ND310 series II with a Yamah HTR-5560 receiver. What do you recomend? Also, I don't want to spend a ton of money.
Unh have you calibrated your speakers to the sub?
You know, gone in and adjusted your speaker output with a test tone and SPL meter and done the same with the volume and crossovers on the sub so that they "blend" seamlessly? I can only assume you haven't. Do that before spending more money when you merely might need to set your system up correctly.
Just some advice..
Da Worfster
Love that new picture worf
Thanks for the love Poneal...
Originally Posted by poneal
***nm***
See above...
Da Worfster :D
