Need help restoring KLH towers
Hello,
I am a newbie so hope this isn't an old topic. I would like to restore my old KLH tower speakers. They are called "Research Ten" model. The 12" woofers are disintegrating and the domed mid-range are sometimes crackly. They used to be excellent sounding so I think it is worth the effort. Where can I find replacement speakers that are affordable and at least equal in performance to the originals? I can send pics if anyone would like to see what I am dealing with. Thanks in advance.
Randy
Try this site for surrounds..
www.winstonorgan.com
The people there are very nice and will custom select a set of surrounds based on your dimensions. I refoamed my Infinity sub and Mission 707's and was very happy with the results. Make sure you buy new dust caps, so you can cut off the old ones and shim the voicecoil, so everything is in alignment. Not hard to do at all. A kit to do a pair of woofers in probably around $30 + shipping.
