Need help with choosing active pa-set
Hey
I was wondering maybe you guys could help :wink5:
Im interested in buying an active pa-set and i don't know which one
would be better: MACKIE SRM 450 SET vs DB TECHNOLOGIES OPERA 405 LIVE BUNDLE .
The difference in price isn't really that different so I don't know
which one to choose...
First i was 100% sure to buy a pair of opera 405 live but while browsing i found out the srm 450 set. Does anyone know what would be the main difference between these two speakers?
Also i would need some help of choosing the correct cables for it; i'd like to connect them to vestax vmc 004 (not fxu...) mixer; it has got only the female rca output so i should get an xlr to rca cable or what? I was wondering what would be better to use a regular xlr cable with rca to xlr so called converter or to buy xlr to rca cable ? Are there any balanced xlr to rca cables tho? Is it even possible? The lenght of the cable should be around 5-10 meters (the longer the better)... Which cable would be best for quality?
