Need to divert low bass to monitor
I want to limit the low bass going to monitor. Monitor goes down to about 60hz. I have a sub with all line and outs, high level in and out speaker post. adjustable crossover,etc...
When you adjust the crossover knob (0-160hz) does it limit the bass to monitor or does it adjust the sub? I'm confused on the hookup here. Also is this the best way to do this? is there a cleaner path? I need a teacher on this one. Maybe Master PO!
Thanks
I'm close. I think, but still confused
Okay, I have separate preamp with only one main out to amp. Do I go from main out from preamp to line level in on sub and then line out from sub to inputs on amp. Then go amps speaker output to the mains? How does the crossover knob adjust the amount of bass back to the amp( limiting the bass letting mid-highs go through) and how do you get the full signal to the sub at the same time? Does setting the crossover low limit the bass back to the amp? Which is what I want: Does the sub retain the bass signal it got from the initial line in to sub?
Thanks again for all the advice!
