Need Advice on Cross Over Freq.
Hi everyone,
I recently bought a Polk CS1 center channel and Polk t15's for the rear surrounds. I am a dunce when it comes to setting the speakers up properly. With the receiver I have, I can select from seven possible settings: 40Hz, 60Hz, 80Hz,100Hz, 120Hz, 150Hz or 200Hz.
I am not sure what the ideal crossover settings should be based on the specs of my speakers.
Polk CS1 (Center Channel)
Overall Frequency Response 55Hz - 25kHz
Lower -3dB Limit 65Hz
Upper -3dB Limit 24kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20 - 125 w/channel
Efficiency 89 dB
Crossover 2.3kHz, second order high and low pass
Polk T15 ( Rear Channel)
Overall Frequency Response 60Hz - 24kHz
Lower -3dB Limit 65Hz dB
Upper -3dB Limit 20kHz dB
Recommended Amplifier Power 20 - 100 w/channel
Any help is greatly appreciated. Take care
