Results 1 to 25 of 75
    RGA
    RGA is offline
    Speakers are somewhat personal but if you can I would go with something larger than the likes of a dulcet from what I can see from the picture of your room. A well rounded bigger more dynamic speaker tends to sound like it breathes easier. The De Capo - but I preferred the sound of the older model - the newer one has a bit of a midrange suckout that is audible - and the tweeter ends up being more noticeable as a result.
    A used set of Audio Note J's beside the window up against the wall would be one option (always is with me so won't disappoint from expectations. Against the wall you'll get down to 30-35hz. Corner would be better.
    Alternatively, I would look into Sonist loudspeakers - they have a ribbon tweeter and a nice non irritating treble band. Integration isn't bang on (never is with very different driver technology in these hybrid systems - but better than usual) and they're modestly priced.
    I don't know what you listen to but if you can't go near wall or corner and looks are important - and you never ever plan to go to SET or low powered amps - and you value something that can hit very hard and play rock that seems like an actual band is in your room and not completely absurdly priced the Gallo 3.5 (not the 3.1) and you may have to look used to afford it - is a terrific heartpounding speaker with first rate bass response. Very clean sound - Personally I think this is the SS lover's dream loudspeaker for that uber powerful presentation. And apparently it is not too terrible for low powered amps either - so.
    Today I played a Nina Simone collection that I had played on the RS6's but had not heard on the OML1's in too long a time. Today's discovery was that the OML1's do funk much better. As Nina and band were getting funky I found myself really grooving to the music. The RS6's do not get funky.
    frenchmon frenchmon's Avatar
    St. Charles Mo
    Is it that the OML's are in a different class than the RS6? Perhaps the next line up in Monitor Audio will be more in the class of the OML's?
    I think it has more to do with sound preferences than a particular brand. The MA's were my first speakers with metal woofer/mids. I have enjoyed a few speakers with metal domes but I think I am happiest with paper and silk. I might enjoy a stand mount MA but the OML1's are doing so well on short stands with their angled front baffle that I think I will be happy for awhile. I still think the cabinets blurred the sound of the RS6's.
    St. Charles Mo
    I tell ya....there is nothing more satisfying to know that speakers that you own are pushing out sound the way you love it. My Cantons do that, but lately I have been looking for a tad more in the bottom end punch...not much but just a tad. But good speakers bring a smile to my face....I have my play list in my head while at work so when I get home from a hard days work of stress....I can sit back in the easy chair and relax while I de-stress.
