Results 1 to 9 of 9
    Jun 2007
    Unhappy Help Fix My Sloppy Box!
    Hey, ah so I have a 15inch competition sub, its ported (box bought separetly) but I want it to be sealed. How can I fix this?
    Currently its more sloppy than Paris after 7 Bacardis (ok not quit that sloppy but its messy none the less) so how can I block the hole?
    I thought of maybe blocking it with a piece of wood, but that would look crap.
    Any ideas?
    Anyone?
    Please help I want my sub tight
    Oct 2006
    You have a sloppy box...that sounds like a personal issue. Ya might wanna check out a car audio site.
    Jul 2006
    you can't just 'seal' it, the port is there for something, it's a ported design, if you want a sealed design, then get a sealed box, with all the damping materials & bracings inside.
    Life is music!
    Mcintosh MA6400 Integrated
    Double Advent speakers
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-103 in midas body
    *Denon DL-304
    *Lehmann audio black cube SE
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Sonic link Black earth IC's
    Siltech MXT New york IC's
    Kimber 4VS speakercable
    Furutech powercord and plugs.
    I'm a happy 20 year old...
    A sloppy box huh? Just go ahead and set me up why don't ya?
    OK, I don't think that you can just seal a ported design. Too many variables. The driver may need a ported enclusure. (note that I did not say box) If you can post the specs to the driver, some here may be able to tell you if it's ok to seal it up.
    Yeah, post the woofer's T/S parameters and your cabinet's internal volume and we'll see what we can do.
    If you can seal it, something like this may help. http://www.corkstore.com/compass/ser...=&functionid=x
    But my guess is that you could make something on your own.
    Out there
    WorkTheBox
    "My Sloppy box"
    "Block the hole"
    "Please help I want my sub tight"
    Yeah, I'm with you GM.
    WorkTheBox
    "My Sloppy box"
    "Block the hole"
    Don't forget the "I've got a 15 inch...."
    JSE
    JSE is offline
    Feb 2003
    Denial
    And he competes with it?
