help choosing the right speakers for Myryad Z140/Z112
Hello,
I need some help choosing the right speakers for my system.
I'm looking for a pair of bookshelf speakers for my Myryad Z140/Z112 system.
I was wondering if the JMR Duet was a good choice.
It's for a small room < 20 square meters.
The music I listen to is: voices, piano, cello… ancient music, baroque music, jazz…
I don't like punchy basses and listen music at a moderate volume.
Is there a better choice or do you think the Duets should fit my needs?
Thank you for your help,
Thomas
