Choosing speakers, need help!
I just bought a Onkyo Integra DTR-6.6 A/V receiver and now I need to choose some speakers. My wife and I mostly listen to music and may watch an occasional movie using our receiver. We listened to some Paradigm Studio 20 bookself speakers and were very impressed, but not with the $800 price tag. A friend of mine tells me not to buy the them, but instead go with B&W speakers. I am also considering M&K speakers but not sure which ones yet. I am open to suggestions and your opinions. I dont plan on using an amp, so i'm not sure on how the B&W's will perforn on that receiver without it. Thanks in advance for your help.
They're all good, but consider this.
You may be limited on power and the Paradigms require lots of power to open up. Not sure about the B&W's or the MKs but you would be well advised to make sure you can return them if they don't mate well with your receiver.
Generally, I advise people to select their speakers first and then make sure that whatever amp they purchase can adequately drive them, particularly when music is the main driving force in the system.
Even though they don't have the panache of the aforementioned brands, the Athena Audition series offer an excellent bang/buck ratio and do a credible job with music.
