Results 1 to 3 of 3
    Jan 2013
    Best Way To Connect System
    Hi All,
    I'm putting together my home office / listening room sound system. This system will only be used for listening to music. Would greatly appreciate your input on the best way to connect these componets up to get the best sound possible.
    Here is what I have:
    * 2012 iMac
    * Onkyo 7.1 HT System
    * KRK Rokit8G2 (2 each)
    * Audioengine D1 DAC
    Is it possible to connect the KRK's to the iMac and have them work seamlessly with the Onkyo system or are there better ways to connect this system up?
    Do I need to get additional componets?
    Thanks!
    Jan 2013
    Hello there (anyone):
    I've recently purchased a Rega RP3 (mounted to cement basement wall) and push it with a Rega Brio R amp. I was looking for suggestions on a few speakers to consider in the $2,000-$2,500 price range. I've heard good things about Goldenear and B & W-any suggestions?
    Philadelphia, PA
    What, if any speakers have you auditioned. If you haven't auditioned any, why not?
    Marcof PPA1, Shure, Sumiko, Ortofon carts
    Marantz CD63SE, Yamaha DVD-S1800
    DAC's: MSB Link, Behringer UCA222, Emotiva XDA-2, HiFimeDIY, Accuphase T101 tuner, Teac V-7010
    Emotiva UMC-200 processor, 2 Adcom GFA-545, 2 modified Dynaco MK3's, 2 bridged Crown XLS-402, Behringer CX2310, DBX223sx, Behringer DSP1124P,2 12" Transmission Line Subs (PASS DIY El-Pipe-O), Magnepan 1.7 (fronts), Acoustat Model 1 ESL's/SPW-1 Woofer (rears)
