barrage of DIY questions about my polk audio subwoofer?
Hi,
Well it's given me musical pleasure (and annoyed my neighbors) for 7 years now, but recently the cone of my 8" subwoofer started breaking up. I'm not sure why, maybe it's just old, or the protection cct isnt doing it's job but I was looking for a little advice about fixing it.
Here are some of the specs, and some questions to boot...
Is there any way to determine if it's the driver or the cone that's blown?
since none of the user manuals (from my receiver or speakers) clearly specify the important numbers, I would like someone to confirm or tell me how to determine these numbers.
First (maybe I should cross post this question) I have a Sony STR-DE915 receiver. I just dived into the back of the wire rats nest to determine the impedence of the connection for the subwoofer (on the receiver). It doesnt say! I expected this info to appear in the users manual, but it only gives the following cryptic info:
Outputs: Woofer: Voltage: 2V ; Impedence 1KiloOhm. I'm not sure if this is under 5.1 or stereo output. Does it matter?
Can anyone interpret this for me?
I assumed that the receiver, being rated for an output of 100W per channel (5.1) means 100W RMS and that the sub is included in this rating, would this be a fair assumption?
I opened up the subwoofer box, pulled the speaker cone and measured the impedence over the terminals of the speaker cone and found 4ohms. First question, is this the right place to measure the impedence? This contradicts the impedence at the back of the receiver (1kOhm).
Another technical point, is there any way of finding out the peak wattage that the receiver pumps out? This is a powered subwoofer, so I looked at the back of the sub and where the mains 110v input is going, it says 120Watts max. Does this mean that the rating of the subwoofer speaker is 120W peak? or is there a big capacitor inside thats charged to pound a big punch when it's needed?
So I believe I need the following specs to purchase an appropriate cone:
size: I managed to figure this out all by myself - 8"
impedence: is it the 1kOhm or 4Ohms or something else (could you please explain the difference)
Wattage RMS
Wattage Peak
I was attracted to this car speaker...
http://www.etronics.com/product.asp?...ore=&catid=374
It's rated at 900W peak and 220W RMS, is this totally overkill?
Would a car speaker be ok hooked up to my powered sub / HT? I imagine that so long as impedence, size and power ratings were the same it would be fine?????
Furthermore, given these specs, can someone out there recommend a brand, price range , bang for buck in mind, supplier websites and any other advice would be much appreciated.
Thanks in advance, cant wait to get my LF back!!!!
Michael
