Audio Note J/L versus J/Spe
Please pass this post by if you're not interested in Audio Note - some people here have been wondering about the different speaker levels from this company and what the scoop is on the differences. A little bit for B&W lovers at bottom.
I went in today to listen to several speakers - this post will be just a comparison of the J's.
System used: Same room all the same gear just changed out the two kinds levels of J's.
Audio Note MEISHU $10,000.00CDN - 8 watt Single Ended Amp
Audio note CD player level 3 (didn't catch the price but assume ~$3000.00Cdn. All wiring from Audio Note
The J/L is chipboard front and back - high grade copper wiring.
The J/Spe Birch ply front and back - silver litz wiring and an upgraded crossover.
The difference in level I now understand - it is basiclaly that when you hear them you are now hearing a totally new level of sound to use a euphamism of sorts. "A whole other level like triple A ball to the Majors - this level you can hit the curve ball which is why you're there and if you can't you're at triple A.
The difference was startling actually because I was extremely skeptical of their level approach. It is noticeable throughout the the range from top to bottome but it was most noticable in the upper midband where a singer would come form the blackness creating more of a 3D effect. The tone in the treble was smoother - and the whole thing sounded less strident.
Now this is only in a side by side comparason because I would take the Cheaper J/L over anything I've heard from the competion up to ~5kUS. So it's no slouch. When you hear J/Spe you can't go back - however. So I didn't want to listen to the higher level and know what I would be missing. Who'd a thunk a bit of better wood some silver would make that big of a difference. So the few who are perspective buyers try if you can to buy the version with the best actual box - you can do the other upgrades later but you can't upgrade the box itself later. I believe the issue is moot because I don't think they sell any current chipboard boxes.
For the B&W owners if you're still reading:
The Meishu amplifier at a mere 8 watts drove the N805 better than I have ever heard that speaker driven - I have used that speaker with Rotel, MF, Bryston Classe and YBA separates(The YBA and Rotel I found the best match and Arcam did a nice job too).
The idea you need mega watts is simply out to lunch - what you need is a real amplifier. If you own these speakers and keep feeling like you need more power to make them sound better and a higher end power amp company --- STOP. What you need is high resolution non-grain adding high fatiguing mess of a ss amp. This is the second time a very low powered tube amp worked wonders with B&W. A Nuvista 11 watt integrated made the 801s sing as well as that speaker has sung for me - though you do need a bit more power to get a high SPL while not getting the amp to run out of gas. Did not try the Meishu with the 801. I was expecting the SET to run out of gas - but on the harder driving of Santana to Albinoni strings to Dianna Krall makes no difference bass was deep and tight with a smooth treble response without the glare but with all the highs. Granted the amp is very expensive(so was the NuVista - interesting made by MF) so are those big SS power amps. Go try out it out - surprised the heck out of me.
