• 12-09-2004, 10:55 AM
    CharlieBee
    8 ohm main & 4 ohm subwoofer, Problem?
    I am new to these sub woofers. My mains are 10 inch Sansui 2500X's and think I could use some more Lo Fi as the old ears have given up on the Hi Fi !
    My old mains are 8 ohm driven by a Sansui 9090db rated at 125 watts/ch RMS at 8 ohms. I said they were old. Most of the sub woofers I see are 4 ohms. I see some subs have two coils and allow both mains to be hooked up to the sub woofer. Is this a problem?
    Thanks
    Charlie
  • 12-09-2004, 11:02 AM
    markw
    Look at powered subwoofers.
    The input impedance of these is high enough to mitigate any problems you might have.
  • 12-09-2004, 02:56 PM
    N. Abstentia
    Yeah, you gotta go with a powered sub. Just simply wiring in 2 subwoofers will probably result in worse performance since your amp won't be able to provide enough power for them and will destroy it's self trying to do so.
  • 12-09-2004, 03:45 PM
    markw
    That, and the LFE output is a "line level" output and needs a power amp to drive the subwoofer anyway.
