Results 1 to 8 of 8
    Dec 2009
    Problem with Sennheiser headphones
    Hello All,
    Some of you may remember my posts about purchasing Sennheiser HD595 Headphones. Well, I did purchase them in December, and I've been very happy with them- up until a few weeks ago. Recently, I've been experiencing some crackling noise sporadically that lasts for 5-10 seconds then goes away. Its hard to say at what interval- because it is happening randomly. Can you offer any advice?
    Thanks,
    James
    Hey james, have you contacted Sennheiser?
    May 2003
    NY
    Quote Originally Posted by james101
    Hello All,
    Thanks,
    James
    Sounds like a dirty plug. It doesn't take much oily residue to cause static/crackling with headphones. Clean the plug with an alcohol prep. DON'T use baby cloths or hand cleaning cloths. Only pure alcohol, either Isopropl or denatured ethel should be used.
    Audio;
    Ming Da MC34-AB 75wpc
    PS Audio 4.5 preamp,
    Jul 2007
    mia fl
    Lightbulb
    yes' James" that advise works ever time!!.... in addition to that it also happens with the headphone out connection from the source your using" if your still having that problem" (unplug the unit" use cotton swabs with the same cleaning suggestion) give it some time to dry" before you power it back up....... good luck
    Chet Baker-Trumpet
    Pepper Adams-Baritone Sax
    Herbie Mann-Flute
    Bill Evans-Piano
    Mar 2010
    What do you have the headphones connected to?
    Passionate Headphone Enthusiast
    Owner, best-headphone-review.com
    http://www.best-headphone-review.com
    Dec 2009
    So the problem is the actual plug, not the connection from the cable to the physical headphone. I should mention I'm using a 1/4 to 1/8 inch adapter...
    If it was me, I would buy a new one and solder it on. As far as adaptors go, make sure you have a nice fit to avoid abusing the plug/cord.
    I asked you about Sennheiser because you should be under warranty...
    Dec 2009
    I am under warranty- but what will they do?
