Question re: power output and volume
After an hour or so of futile web searches I'm back. Is there a direct relationship between power output of an amplifier and volume?
Put slightly differently, if I achieve a certain volume or loudness with an amplifier rated at 60 watts/channel, through a set of speakers, then switch to another amplifier rated at 110 watts/channel and return to that same volume, am I correct in assuming both amps were outputing the same amount of power at that volume, all things equal?
