ps3 high def audio review and help.
hi all! just wanted to let anyone know about the high def audio on the ps3.i have absolutely come to the conclusion that if you have a receiver that has hdmi 1.2 or 1.3 definatley select linear pcm in your blu-ray settings on ps3.but you try it and say thats not very loud.well go into ps3 menu during playback and select audio volume and turn it up to +2.and bam your listening to high def audio and it rocks.but also remember this all depends on the quality of your reciever and how much power it has.but if you choose bitstream in the ps3 blu-ray settings turning up the volume in the menu has no effect.i have read in alot of forums people were confused about this.now remember if your reciever doesnt support hdmi audio 1.2 or 1.3.all you can enjoy is 5.1 dolby digital which really isnt all that bad.it just doesnt have the fidelity and soundstage like the high def audio does.i hope this helps anyone that doesnt understand.it took me awhile thats fer sure. sean
