Help me improve picture and sound quality please
I just got one of those new Dishnetwork boxes that control 2 TV's with one unit and have 2 seperate DVR's built in that run independently. Its pretty slick.
For the 2nd TV there is a coax out and it runs from my master bedroom to my kitchen through a coax cable. I had a crummy TV at first, so the picture and sound looked ok. I just put up a stereo lcd tv and now the picture doesnt look so hot and the audio is in mono. The picture isnt horrible, I jsut think it could be better (but I could be wrong)
The cables are already run through my house and through walls, so running more cables from my bedroom to my kitchen are not an option. Everything is running off this one coax cable to my kitchen.
The back of the Dishnetwork receiver has both RCA and s-video outputs that you can run instead of coax. Is there an adaptor for s-video to F (coax) that I could put at both ends of the coax and use the s-video out on the receiver and s video in on the TV? Would this improve the picture quality?
For the audio, I was thinking of using a wireless transmitter that would plug into the rca outs in the receiver and the RCA ins on the TV. Hopefully someone makes speakers that could accomadate this setup that would clip onto my TV? Anyone make a good stereo wireless transmitter that would fit the bill?
My LCD is hanging on the wall with nothing around it. It looks so clean as there is only a coax cable and a plug that are behind the receiver so you see nothing but the LCD. I want to keep this look and avoid paying 6 bucs a month for another receiver.
The distance from my receiver to the kitchen LCD is about 100 feet and it would be next to impossible to route more cables as it has to go through multiple walls with no crawlspace or attic access.
Anyone have other suggestions?
Thanks in advance
