Firmware problem denon avr3808ci
Recently purchased AVR3808CI Denon Amp. Yesterday I tried a Firmware update for the first time. The unit almost made it through the entire process until the end. I get an "Ether WP 06min, update failed" message. I tried turning off the unit, it goes through the same sequence of events with the same outcome. I contacted Denon, was told to reset the processor and redo the update, we tried this several times with the same outcome. I was then told by Denon that the unit needs to be serviced, which would be fine. The only problem is, it is the center of my home theater viewing. No receiver - no TV, no nothing.
If anyone has any suggestions or has encountered this problem before, any help would be greatly appreciated.
This is my first time posting a thread, think I accidentaly put it in a blog also.
Thanks,
