Results 1 to 3 of 3
Thread: Onkyo TX-SR545
    Dec 2012
    Onkyo TX-SR545
    Looking for a power supply unit for my Onkyo TX-SR545. It is an old A/V Processor but worked great until power supply got fried.
    Does anyone think I can find parts for this older unit? No real luck on the web so far. Still looking.
    Upgrade no an option finacially right now, thought I could save by fixing the old girl..
    Thanks
    Chad
    Jul 2002
    Quote Originally Posted by u269917 View Post
    Thanks
    Chad
    Chad, I am going to be honest with you. There is zero benefit from trying to recondition an old low level receiver. There is much more value in replacing it with a higher level(but not so much higher) HDMI based equal level Onkyo receiver. The reality is you could replace it with a similar priced newer receiver, and get far more benefits overall.
    I would look beyond this receiver for a newer near or equally priced one, and get more benefits from the process.
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    New York
    Its not worth the trouble trying to fix it. You can find a similar used model in very good condition for not much more than a new power supply would cost. Look around on eBay.
    onkyo in Home Theater Receivers | eBay
