Found some possible answers!
Originally Posted by bubbagump
If so, you can connect the turntable to the pc or mac and then use a wireless device.
The Turntable is isolated in a corner of the lounge, hence the need for something small and relatively self-contained to transmit the signal. I came across these little gizmos on Ebay:
http://cgi.ebay.co.uk/2-4Ghz-wireles...QQcmdZViewItem
No idea as to the quality of transmission but these are, in a nutshell, what I need - A 2.4GHz wireless transmitter/receiver pair with phono inputs
Don't forget that you'll need a phono preamp as well.
"phono" is a type of plug in this case. A phono cartridge puts out a very small signal which needs additional amplification before it's usable by the rest of the system. RatShack sells 'em for around $30 or so. ...they go up from there.
