Results 1 to 22 of 22
    Nov 2005
    Help!!. confused about CD/DVD etc?
    Hi
    I am going to buy a new 5 disc CD player. I have discovered that their are some formats that i think it should support. But i am confused about them or rather if i need them at all.
    I was looking for CD and MP3 format palyer. But do i need an Audio DVD format? Will it catch on and is there any DVD Audio discs out there for sale?
    Do i need SACD? again, is there any discs out there to buy?
    I have always been happy with regular CD sound quality.
    Should I buy a CD/video DVD player?
    Im so confused.
    I have just purchased a Yamaha receiver RXV557 and Polk speakers RM6005 based on advice from everybody here.
    I do not need a DVD video player. i have a new but very basic sony DVD video player.
    Any advice? I have seen the following 2 players
    SONY SCD-CE595 SACD player. no MP3 or DVD audio support.
    SONY DVP-NC875DVD/SACD. it plays DVD video, MP3 and CD but not DVD audio .
    Cheers
    kev
    Do you need DVD-A/SACD? Well that just depends on how serious you are about high-res music. Personally for me, it's a must.
    There are plenty of SACD's and DVD-A's to buy, I get mine from the usual stores...amazon.com, buy.com, dvdempire.com, even the BMG music club carries SACD's.
    I would also avoid Sony players due to quality problems. You can get a much better player for the money. Why not look into a matching Yamaha?
    Nov 2005
    Thanks
    Nice system!! i checked out your website. You have a great AV system. My back ground is in prfessional broadcast television so i am used to good sound. However, truth be known, i am happy with an MP3 CD on my system. So perhaps i do not need SACD. i was more concerend with buying a CD changer/player and finding out that next year CDs are out of date in favour of A-DVD.
    I like the Yamaha CD player, i will look into that. Its well priced too.
    What do you think of your Sony DVD changer? the 300 disc one. I was considering the that for my self but to be used mostly for Audio cd playback only. My concern is that i mostly only play 3 or 4 favourite cds in random mode and i had read that to set this up on the sony was quite a lot of work? based on that alone i decided t ogo for a 5 cd changer. I thought MP3 play back would be useful. ?
    kev
    I have the same Sony 300 disc player and I love it. It really doesn't take much to set it up and it's pretty intuitive and you can even plug in a keyboard and type in the titles to the CDs. For your purposes you can "group" a few CDs together, select that "group" and then hit random.
    As far as your original question goes, universal players, components that will play: DVDs, CDs, MP3-CDs, SACDs, and DVD-As are pretty cheap for decent sound quality, so I say, why not? But don't worry, SACDs and DVD-As are not going to take over the market any time soon.
    Forum Regular PAT.P's Avatar
    Oct 2004
    ont ,canada
    I bought the Yamaha DVD-C750 5 disd DVD AUDIO/Video SA-CD changer to go with my Yamaha receiver.It plays most format available ,and the better Yamaha is the DVDS1500.Still trying to get use to it,its a bit slow to load.
    Nov 2005
    Thanks Guys
    THe Yamaha DVD-C750 sounds good.
    I am now thinking of the Denon DCM380. What do you all think of this? I can get it for$380CND ($325 US) from a local store. It has a special DAC in it that makes it sound good apparently. it also plays MP3 and HDCD what ever that is. THe reviews seem good but refer to it as a budget CD player.
    PS, My Polk speakers arrived today so tomorrow is a setup day for my new system and CD if i go get it. I realy prefer to shop localy but that realy limits my choices as i live in a small town. Localy i can get a yamaha CDC685 for $260cnd and the Denon DCM380 for $380cnd. I am replacing a solid 11yr old Marantz CD player and so want to put in a good replacement.
    Any thoughts on the yamaha vs Denon?
    cheers
    kev
    SF Bay Area
    As others have said, whether you need DVD-A and SACD depends on how interested you are in exploring those high res formats. IMO, multichannel music can be a revelation and even without a universal player, I've been buying DVD-A discs because they all have DVD-video compatible layers with DD, DTS, and/or PCM tracks that will play through any home theater receiver. Since you already have a DVD player, a universal player would indeed be redundant, but audio-only disc changers are a dying breed and you might need to get the video capability even if you don't need it.
    That Sony CD/SACD changer that you listed is a good player, and it's specifically marketed as a CD changer replacement. It uses good DACs and sounds excellent with both CDs and SACDs. I recently bought the ES version for $240, and so far I've enjoyed it immensely. The advantage of the ES version is that it has a few upgrades and a 5-year warranty that might come in handy given Sony's spotty reliability record in recent years. Still, the regular version of that CD/SACD changer goes for only $150 at Best Buy. Since you're looking audio-only, that might be worth checking out. I bought a SACD player because there were specific discs that I wanted to listen to and unlike with DVD-A, SACD does not have a DD or DTS-compatible 5.1 layer available.
    I've gone SACD! (And I like it!)
    The problem with universal players is that you don't have a lot of choices if you're looking for a five-disc carousel. I know that Yamaha makes a universal five-disc changer that sells for around $300 and can do DVD-A, SACD, and MP3. None of Denon's universal players are carousels.
    http://www.yamaha.com/yec/products/DVD_CD/DVDC750.htm
    Nov 2005
    Hi
    Ok, I realy like the yamaha DVD-C750. It gets great reviews and plays all formats. If i cannot get it via my local yamaha dealer (they have no listing for it) is there a good on line retailer here?
    ETRONICS and BRANDNAMEZ are advertisign it. Are they good retailers? I have never heard of them.
    kev
    Aug 2005
    Posted in da cut
    Quote Originally Posted by kevan
    Hi
    kev
    Hey Kev, this is from the Yamaha site.
    The Yamaha Limited Warranty applies only to products purchased from authorized dealers.
    Yamaha's Authorized Internet Retailers:
    Abt Electronics
    Audio Advisor
    B&H Photo
    Best Buy
    J & R Music
    Your Electronic Warehouse
    One Call
    Sears
    Sixth Ave
    Stereo Advantage
    Tweeter
    Vann's Electronics
    Oct 2004
    ont ,canada
    Hi
    kev
    Good choise ,I really enjoy my Yamaha DVD-750 .
    Nov 2005
    Rite then... Apparently Yamaha no longer makes this or any other simular item. So i will have to mail order from the states. I will look for one from a registered dealer.
    If not I GIVE UP. I will buy the basic yamaha 5 disc CD only and wait untill this A-DVD / SACD becomes more popular and so more widly avaialable. its getting frustrating but that because i always do my research...probably too much research.
    Kind regards all
    I will keep ou all posted as to my progress.
    kev
    Nov 2005
    ok
    What about this one?
    Sony's DVP-NC60P DVD Player with 5-Disc Changer
    id does cd, mp3, SACD.
    It doesnt support A-DVD though.
    I can get this loacly for under $200 cnd.
    Is it any good? does any body have one?
    cheers
    kev
