Results 1 to 7 of 7
    Feb 2010
    CD players for listen stations
    Hey guys,
    I could find a thread for this so apologies if this has already been asked.
    I work in a music shop and we have 8 listen stations all wired up but only one cd player, so, i need to buy some more. i need a cd player with what looks like a serial port on the back, only thing is i have no idea what the the description of the "serial port" actually is.
    Basically i need 7 cheap versions or something similar to the denon dcd 615.
    Many many thanks in advance.
    Quote Originally Posted by Airstripone
    My guess is that what you need is a computer (where serial ports are found) and not a collection of CD players. The stations you find at places like Barnes and Noble which play clips from a number of different albums most likely access a computer based music server - just as you would find going to Amazon.com.
    Dallas, TX
    What you're describing is the RS-232C interface. How much can you afford to spend? They're pricey by comparison to the average mass-market CDP.
    http://www.buy.com/retail/product.as...ingid=52130268
    http://www.jr.com/yamaha/pe/YAM_CDC600BL/
    http://www.vanns.com/shop/servlet/it...key_id=6224238
    http://www.advancedlamps.com/Denon-D...548fc63a14a3ed
    Feb 2010
    thanks for the response guys, jus had a look but the RS-232C is smaller then the one i need, where this is the average size of a VGA cable mine are more like a parallel connection ( sorry i said serial) like the old printer connections. arrgggg this is a nightmare
    Dallas, TX
    Sounds like you need a whole new system.
    I would take eight portables, glue them to a board, glue a headphone into each.
    But that is just me.
    I am just surprized to hear of a dedicated shop still selling CD(ALTHOUGH we do have one here in town).
    Jul 2004
    You should find those Nakamichi listening stations that HMV and Tower Records use in Japan
    Emotiva UMC-1
    Emotiva XPA-3
    Peachtree Audio iNova
    Rega Brio-R
    Rega RP-1
    Sony PS3
    BAT VK-D5se
    Totem Acoustic Dreamcatchers
