What is the difference between Watt and Volume?
People say that if the amp has 100W more power, the sound will be 3dB louder. But with the volume on the pre-amp, you can make the sound as loud as you wish. What is the difference?
Numbers and audio don't mix very well
There are a few things to keep in mind here. The vast majority of your listening is done well below 1 watt. 1 watt is VERY loud. How loud? that depends on your speaker's sensitivity, but even on relatively piggy speakers, it's loud. (don't take the word "piggy" as bad. Designing a woofer to go deep accurately means that you sacrifice sensitivity or loudness per watt. Life is full of tradeoffs).
Now, back on the subject of watts. A watt rating on one brand of receivers isn't going to equate very well with a watt rating on another, especially if you are going from an entry level line (Sony, Pioneer, JVC, Panasonic/Technics, Kenwood, etc) to a more upscale line (Yamaha, Denon, Marantz, h/k, etc). The entry level products are designed to look good on the spec sheet to get uneducated consumers to think they are getting a deal. The upscale brands are designed to more effectively deal with real world speaker loads. In other words, a lower rated upscale receiver will typically play louder, longer than an entry level receiver with a much higher watt rating.
Notice I didn't use the word "power". Power is the ability to do work, an audio "watt rating" is the ability to pass a very basic test that isn't based on reality. I don't feel it is appropriate to confuse the two concepts.
So, without knowing it, you asked a question with about 100 million possible answers. BTW, a preamp will not add any power to an amplifier. You get what the amplifier can do into the load presented by the speaker you choose. What the potential maximum output will be changes by the millisecond. Sometimes it can be pretty high, sometimes it will be very very low. So given the choice between more and better, choose better. You will be glad you did.
