What is cheapest way to get MP3 from computer to stereo?
I've been working on this project for a while and have posted some stuff here and gotten some great help.
First I tried to run digital coax from Audigy 2 and ran into problems on digital inputs on my Sony 333ES being full.
Next (and currently) I split the sound off my front speaker output from the Audigy 2 and ran an analog signal to my receiver and simply ran it into an unused input. I immediately ran into hum issues from all the wires I was using. I upgraded the wires to some shielded Monster cable and got rid of about 3/4 of the hum...but there is some still there at higher volumes.
So now I'm looking at getting the digital signal from the computer...through the wall...to the stereo and then changing it to an analog signal which can then be plugged into my stereo. An great (but expensive) example of this is found HERE. But I'm not interested in having this be wireless or having an LED readout at the stereo or a remote associated with it.
I simply want something that will take the signal, run it to my network hub, then to a box at my stereo where the signal will be converted from digital to analog and then output w/ left/right stereo signal which I could then run into the stereo.
Audio from pc to home stereo
Hi Guys, first post here. What I did is run an optical line from my sound card to the back of my HK 210, now this is the cool part. It plays anything winamp will, so I can play wav, mp3s, flac, shn & ape. Now that's cool! (imho)
Wow!!!... That looks like the way to go!!!
The Xitel Pro Hi Fi Link looks awesome and I'm probably going to buy one. Thanks for the link kaltfuzion!!! If you want to do this cheaper, you could try not spliting the output from your Audigy2. That's probably what's causing the hum. Or a defective cable (Audigy2 won't give you the absolute best sound quality, but shouldn't give you problems with noise). Would be a pain switching the plugs to the computer speakers and stereo as needed. Know I've seen switch boxes that would solve the problem, but looks like the money would be better spent towards the Xitel Pro Hi Fi Link. (Solves hook-up problems, betting on better sound, Dolby Digital if you use the digital outs) This thing looks REALLY cool!!!
Now I have a question too!!!
I have the original SoundBlaster Audigy. Also have plenty of digital inputs on my receiver. Could I hook my Audigy straight to my receiver digitally and get similar funcionality as using the Xital Pro? What about with an Audigy2? Could probably find one cheaper than the Xital Pro. Thanks much if anyone knows. Joining the home theater and computer is definitely my next step. Have TV outs on my video card (ATI All-In-Wonder) and a wireless remote that came with it, so I have a pretty good start. Just haven't gotten around to doing it yet.
That looks interesting too...
Should already have the remote part covered though. ATI All-In-Wonder came with a RF remote I can use in the other room to control anything on the computer (media players, web browsers etc...) while monitoring on the big screen. (hooked up to the TV out on the computer's video card) Just haven't completely thought out the audio part yet. Bought the Audigy OEM, so I didn't get any instructions with it and I'm not quite sure of what it's capabilities are. I knew I didn't want to try splitting the analog outs from the sound card, or be endlessly plugging and unplugging things, so I just never got around to finishing the project. Guess I'll have to quit being lazy and check out the Creative web site for more info on my sound card and give the instructions for my receiver's digital inputs another good look.. If that won't work, the Xitel Pro Hi Fi Link sure looks like what I need and it's not too expensive.
Thanks!!!
That's about the best you can do.
That's as good as it's going to get without using a digital connection or getting a better sound card. I just need a way to get the sound to my home theater in the other room and to my computer speakers at the same time. Don't want to use a splitter. Using this Xitel device or possibly just a digital cable would add the capability of transferring a true Dolby Digital signal to my home theater receiver as well, which would be cool for playing movies stored on my hard drives. Gamers would probably dig this feature too, although I'm not really into that. Also, I have briefly tried hooking up the analog out on the sound card to my home theater. Wasn't really impressed with the sound (although it wasn't terrible). A digital connection may be better. Strange thing is the Audigy card seems to do a fantastic job of recording. The output doesn't seem quite up to par when hooked up to my big system though.
