Page 2 of 9 FirstFirst 1 2 3 4 ... LastLast
Results 26 to 50 of 201
  1. #26
    Dynavector DV20XL, Souther SLA-3i, VPI Scout, Monster HTS-1000, VPI HW-16, GamuT CD-1 / DACT passive attenuators, ARC SP-9MKIII, VTL MB450 Reference, Acoustat 2+2, JPS Labs cables
  2. #27
    Sep 2003
    Warner Robins, GA
    Mitsubishi WS55511 HDTV
    Sony DA7ES Reciever
    Sony RCD-W50C 5 Disk CD Recorder
    Sony CDP-CX225 200 Disk CD Changer
    Sony SLV-779HF VCR
    Pioneer DV-667A DVD, SACD, DVD Audio Player
    Sony RM-AV2100 Universal Remote
    Sony SS-MF500H Mains
    Cerwin Vega LS-5 Bookshelf Surrounds (4 ea.)
    Cerwin Vega LS-5C Center Channel
    Cerwin Vega LW-10 Sub
    RCA Direct T.V. Reciever
    And hand built entertainment center and sofa table.
    http://groups.msn.com/mudcricket/myh...to&PhotoID=697
    ~C.C.~
  3. #28
    Smile That gives me a chuckle!
    Quote Originally Posted by Mwalsdor_cscc_edu
    Why not? MikE
    Why don't ask me to list connectors?
    You know the answer already, Mike, or at least part of it. The main reasoin is that in my considered opinion different connectors will make no audible difference, or if you wish to follow strict formal logic, are unlikely to make an audible difference.
    There is a second reason, too: frankly, I don't know what brand some of them are, I've had them so long.
  4. #29
    Forum Regular jeskibuff's Avatar
    Question Dark pictures
    In comparing the pictures posted so far, I find harleyx's and gonefishin's to be extremely dark and E-stat's on the dark side. My pictures probably look really washed out in comparison.
    I think this probably is most likely due to how we each have our monitors set. I have the Photoshop software which I used to calibrate the settings on my home monitor, although it is not an exact science. The end result is that the colors are quite vivid. The same pictures on my monitor at work don't seem to have as much impact.
    I cranked the brightness of my pictures I posted up a bit to better see the equipment, so they aren't totally "accurate", but it looks to me by the pictures others have posted that they may have the brightness cranked up too high on their monitors. Am I in the minority here?
    I've brightened up one of the posted pictures so I can see the equipment better. I attached the result to this post. So my questions are...do most people think the other pictures are just fine?...are the other pictures dark just because the posters have no means to correct them?...how many other people "calibrate" their monitors.
    P.S. The "adjusted" picture of Gonefishin's system I attached looks really washed out to me, but it allows me to see the equipment rather than providing an accurate color rendition of the room.
  5. #30
    Audio..Nutz Harleyx's Avatar
    May 2002
    Alberta, Canada
    Talking Sunglasses On...
    Yea, it looks fine on my monitor.
    Oh well, I brightened it up a bit. Photoshop 7...great program, if I knew how to use it...)
  6. #31
    drichardson
    Gear
    Quote Originally Posted by Chris
    I'm sure this has been asked many times before, but there's a reason I'm asking.... you now have a field in your profile where you can enter this information (called "equipment list") and never have to type it out again. Imagine being able to just point people to your profile to tell them what you own. Fill in your profile and reply to this thread so we can check it out!
    Come on guys, let's see what you got!
    I own the following gear:
    Fronts - Klipsch Tangent 50's
    Center - Klipsch KV2
    Rear - Definitive Technology BP1's
    Extra - Infinity Kappa 6
    Subs - Custom made 15 inch subs (2)
    Amp - Yamaha P2100 (3)
    Amp - DBX BX3
    Crossover - Paradigm X-30
    Preamp - Citation 7.0
    DDpro - Pioneer Elite SP-99D
    DVD - Pioneer dv250
    VCR - Proscan Hi-Fi vcr
    Mixer - Behringer UB2442FX-PRO Mixer
    Computer - PIV 2.6 with optical and coax digital out's, equip with cool
    edit 2.0, wave lab, 80 gig hdd, multiple cd burning capability
    Television - RCA 31"
    Projection - Kodak LC 500 lcd projector
    Screen - Da-lite Model B 100" 4.3 video format matte white screen
    Keyboard - Alesis QS-7
    Scaler - Inline 1424 line doubler/scaler (used to convert composite
    signal to RGBS - will use as line doubler when I upgrade the
    projector
  7. #32
    Sep 2003
    Yamaha 5250 Receiver
    Philips Cd
    Sony S560D DVD Player
    Pioneer 563A DVD Player
    Yamaha Turntable
    M&K 750thx Fronts
    M&K 750thx Center
    Paradigm Sub
    Jamo Rears
    Samsung 50" DLP TV
  8. #33
    Forum Regular Mwalsdor_cscc_edu's Avatar
    Jan 2002
    Columbus
    Pat
    Glad to provide the laughs [least I'm good for something]. But seriously I believe it is important for everyone to disclose such data as equipment history, experience or educational background so that the readers can make a more informed opinion about they're credibility. For instance, when someone discredits a particular brand or equipment type it would be relevant to know the extent of their exposure to the equipment in question. Of course, the decision is entirely your's as to what information you choose to provide and the reader's to evaluate.
    MikE
  9. #34
    Sep 2003
    Warner Robins, GA
    Unhappy
    I had hard time taking my pics. My room is really dark and if I used the flash on the camera it would either wash everything out or if I got a reflection it would auto dim. If this happened it would be so dark you couldn't tell what was what. I only have a 3.0 mp camera.
    ~C.C.~
  10. #35
    il
    Sources-Denon 2900 (For sacd only) Esotric P-500 Transport-Audio alchemy DTI-PS Audio Digital Link (For cd) SOTA Sapphire-Sumiko FT3 Tonearm W/Blue point Audio Research SP9 mk2 VTL Compact 80 Monoblocks (5881 Output tubes) Joseph Audio RM7si signatures resting on 27 inch high sand filled Lovan stands and for low bass a Sunfire True subwoofer mk4 run of the speaker taps of the VTL's
    Cables- All digital cables are Cardas W/ Nordost Blue Heaven to preamp Pre to amp Cardas Quadlink 5C Amp to speaker Nordost Blue Heaven Bi-wire for the JA's and Super Flatline to Sub
    Power- Monster cable HTS 2000's amp outlets for the VTL's and a Tripplite LC 1000 Voltage regulator for the sources and preamp. The Denon 2900's powercord is a PS Audio Prelude and to finish Audioprisum Quietline filters throughout the house
    VTL's are on a dedicated 20 amp line and the sources are also on a dedicated 20 amp line. The room is located in the basement and is for music only and is treated with ASC tube traps plus 2 inch sonex.
  11. #36
    profile
    hi chris,
    when i tried to fillout the profiles equip list, it cut off very quickly. has this been fixed or is the space still so limiited.
    i dont want to do that again to only find that ive wasted my time again.
    ...regards...tr
  12. #37
    What I did was put post my system picture and description in this thread and put a link to the post in my signature area. I think this is a good alternative, except for the fact that the capability to edit one's post beyond a 24-hour timeframe has been turned off. Can we change that, Chris? Is there any particular reason for putting that restriction in place?
    Click here to see my system.
  13. #38
    if you look
    i linked to my AA system. best short work i could do, editable anytime.
    ...regards...tr
  14. #39
    Feb 2003
    Midwest
    Starting Out
    McIntosh C36 - preamplifier
    McIntosh MC2505 - amplifier
    McIntosh MQ101 - equalizer
    Marantz 6300 - turntable
    Klipsch Quartet - speakers
    MIT Terminator 2 - speaker wires
    Monster - interconnects
  15. #40
    AR Maniac
    Sep 2003
    Newington, CT
    Mits311 65" HD RPTV
    Yamaha RXV995 receiver
    Yamaha CDC735 CDP
    Pioneer CLDM301LDP
    Mits HSU510 hifi VCR
    Pioneer DV563A DVDP
    Panasonic ATSC HD tuner (not sure of the model picked it up at Bernies for $100, originally priced @1,495. It is very heavy.
    DirectTV HBH DD rec.
    Polk RT 16 main spks
    BIC DV53CLR center channel
    BIC surround spks
    KLH sub
    All Monster audio and video inter connects.
    Monster M500 Svideo
    Monster Mseries spk wire front LCR
  16. #41
    ...regards...tr
  17. #42
    My system...
    Here goes...
    Panasonic PT-47WX51 HDTV widescreen
    Scientific Atlanta 3100HD HDTV set-top box (rented)
    Denon AVR-3300 receiver
    Panasonic RP-56 progressive scan DVD player
    PSB 800 Century mains
    PSB 200 Century center channel
    PSB Alpha surrounds
    DIY Adire 12" Rava sub w/ 150 watt plate amp
  18. #43
    My custom user title This Guy's Avatar
    PA
    alright
    Receiver:Marantz SR-5200
    DVD: Samsung 5 disc
    Front left and right: Jensen C-7 , put new mid and tweeter in there so now it has a 1" titanium bulet horn tweet and a 3" midrange cone that was lieing around. It the next month or so I'm just gonna buy a Bohlender Graebner planar mid/tweeter to replace the midrange, and maybe I'll put in a bullet as a super tweeter. I'll also get rid of those crappy Jensen woofers and get some nice Goldwoods.
    Center:Old optimus cabinet, Goldwood 5" woofer and audax tweeter, I'll see if can put a bullet tweeter in there soon.
    Surrounds: DIY 6.5" woofer and Piezo tweeter, the high frequencies sound terrible, so again I'll put in a Bullet.
    subwoofer: Not really a subwoofer, but gets me down to the high 30's, it's a folded horn with a 6' path and a 12" driver. Called "The Konk", It was a good PA speaker in the early 80's. It goes extremly loud and if you stand up while playing it loud, if feels like someone is literally punching you in the chest in this 10 by 12' room.
    Amplifiers:Old Pioneer bridged to 150 watts for the center speaker. Also I have an Audiosource Amp Three bridged to 400 watts for the subwoofer.
    Game systems: PS2 and the Xbox.
    TV: 32" RCA, the one with the vport is use for the xbox
    Yes i do know i'm very spoiled with having a Dad that would give me the subwoofer, surrounds, and center he made. It also helps having brothers that are willing to help pay a little for some of the equipment.
    -Joey
  19. #44
    Hayes, Va
    my "stuff"...
    Two Channel Main
    Adcom GFA 555 mkII
    Adcom GTP 500 mkII
    Adcom GCD 600
    Adcom GCD 575
    Adcom GCD 600
    Monitor Audio 210 Sub
    Paradigm 100's (rosewood), tara lab connectors, 1219a belden cables (homegrown) bi-wired
    Two Channel bedroom
    Carver TFM-25 (Bi-Amped)
    Carver TFM-55 (Bi-Amped)
    Carver CT-17 pre-amp
    Parasound CD 100
    Klipsch Chours II
    HT System
    42" Sony Wega
    HK Receiver (Junk)
    HK 5 disk CD (junk)
    JBL Tower Speakers (so-so)
    Energy Take 5 surrounds (nice)
    nOrh 4.0 wood center (sounds great)
    HK sub (lame)
    ** Going w/nOrh all the way around in the furture and picking up svs/hsu sub. Also picking up and Outlaw 500 Receiver.
    Firehouse Bunkroom system
    Fisher Amp (65 wpc, nice solid vintage amp)
    Adcom 500 pre
    Pioneer Elite CD
    nOrh 3.0
    • Mark Levinson No. 27
    • Musical Fidelity 308cr
    • Martin Logan Prodigy's
    • Ariel Acoustics 10-T
    • Rega Planet CD
    • CJ Premier 9 DAC
    • Benz Micro Cart.
    • Akai GX 747 Reel to Reel
  20. #45
    North Ridgeville, OH
    Pioneer Elite
    Hitachi 57S500
    Pioneer Elite VSX-43TX
    Pioneer DV-563A(DVD)
    Onkyo DX-C390(CD)
    Samsung VR8260(VCR)
    Cerwin Vega LS-12(Main)
    Cerwin Vega LS-6C(Cen)
    Bose 201 Series IV(surr)
    Cerwin Vega E-76C(Rear)
    2 Cerwin Vega LW15(subs)
    Sony PS2
  21. #46
    JBL Whore Bobby Blacklight's Avatar
    New York
    Hello All
    My mains system is combined Stereo and HT
    Speakers are home brews JBL drivers
    E145 15" woofers 2123 10"mids and 2416 compression driver on 2344 horns Center is a Urei 811C Coax 15" clone. Rears are JBL L20T's.
    Subs are 2 home builts with JBL Le14 woofers and an ARHO12 for LFE
    Amps are 3 Crown PS-200 for the mains, Center has a strapped Crown DC-150A Rears are driven by the front channel on my Sony GA8ES reciever.
    Active crossovers are JBL M552 and M553
    EQ's are Urei 539 on the front 3 channels
    Reciever/Preamp Sony GA8ES
    Sony CD CA7ES and CA70ES
    DVD/SACD Sony NS755
    VCR Sony???
    Turntables Dual CS5000 Empire 698
    Cables all sorts mix on balanced and unbalanced components. Speaker wire 12Ga.
    Rob
  22. #47
    PA
    sweet
    This is the kind of system I like to see/hear. I bet it's loud as hell, too. One question, where do you get all your JBL drivers?
    -Joey
  23. #48
    New York
    Hello Joey
    Got most of the drivers from Ebay. Took a while to get them all together but it was worth the wait.
    Rob
  24. #49
    Carver HR-772 receiver
    Carver TDR-2400 cassette deck
    Carver SDA-390t vacuum tube 5 disc CD changer
    Klipsch KG 2.5 speakers
    Yamaha subwoofer
  25. #50
    Jan 1970
    California
    Cool system
    Bedroom:
    Pioneer VSX D411 just upgraded from VSX D309
    Pioneer DV-525
    Phillips VCR HiFi
    Phillips 19" TV
    Speakers:
    Fronts: Optimus Pro X77's
    Center: Optimus C3
    Rears: Optimus Pro X77's
    Sub: KLH SW120
    HT
    Pioneer Elite SC lx502
    Pioneer Elite N50
    Pioneer Cassette CTM66R
    Pioneer Elite BDP 85FD
    Vizio P series 2160p
    Panamax 5300 EX
  1. What, No Tube Audio Forum?!!!
    By Mwalsdor_cscc_edu in forum General Audio
    Last Post: 11-24-2003, 11:09 AM
  2. Testing the digital audio output
    By mpm32 in forum Home Theater/Video
    Last Post: 11-20-2003, 09:59 AM
  3. fluance audio
    By mx6er83 in forum Speakers
    Last Post: 11-19-2003, 12:31 AM
  4. Audio tron or Creative Wireless Music??
    By twwesn in forum Digital Domain & Computer Audio
    Last Post: 11-16-2003, 10:02 AM
