In wall wiring question
Printable View
  • 05-18-2005, 06:53 PM
    csrusa77
    I wired a surround sound system with inwall speakers all around. I used regular 18 guage speaker wire. I also ran this wire for the sub through the wall to the back of the room (about 40 feet) I connected RCA jacks to each end of the wire but the sub doesn't work through this connection.
    I know the wire is in good shape so I think I'm using the wrong connectors or maybe I just attached the connectors to the wire incorrectly.
    Any help would be appreciated.
  • 05-18-2005, 07:02 PM
    Speaker wire?
    Are you saying you terminated regular speaker wire with RCA's?
  • 05-19-2005, 06:01 AM
    csrusa77
    Yes.
    I attached RCA plugs to each end of the speaker wire.
  • 05-19-2005, 05:50 PM
    Well that probably won't work...
    Yes.
    You'll need to purchase long-distance in-wall RCA cables instead and run those to the sub instead.
  • 05-20-2005, 02:14 PM
    csrusa77
    Oh, I didn't know they made in-wall RCA cables.
    Thanks, I'll try to find that cable.
  • 05-20-2005, 02:50 PM
    In-wall
    What I meant by in-wall, is sturdy and corrosion-resistant, the type you would find at a hardware store. Although that probably won't be high-quality. If you want hi-fi, you'll have to pay a lot more for this type of cable. The best solution in that case would be to order this custom-made by one of the name-brand manufacturers like Monster or AudioQuest.
  • 05-20-2005, 07:15 PM
    Tahoe Gator
    No, no, no. What you want to use is coaxial cable, e.g., "RG-6" coax like your cable company uses. Put the standard "F" connectors on each end and then use "F" to "RCA" converters to make the connections at the sub and receiver. Better yet, terminate each end of the coax with a RCA wall plate and then just use a regular RCA cable for the short distance. The reason you need coax is that it is "shielded" ... in other words, like RCA cables, the conductor is inside a shield and thus protected from interference. Don't buy a 40 foot RCA cable ... RG-6 is much less expensive and works just as well or better if you use high quality cable.
  • 05-25-2005, 06:08 AM
    csrusa77
    thanks gator
  • 06-04-2005, 03:39 AM
    garmonjo
    Do you have any advice for running in-wall speaker wire to rear speakers? I plan on using 12g wire. I want to get the wire set before the drywall goes up.
    Thanks!
  • 06-04-2005, 11:19 AM
    Tahoe Gator
    Thanks!
    The only real advice is to keep the cables away from power wires as much as possible. If you have to cross them, try to do so at as close to a 90-degree angle as possible (basically, avoid running parallel to power).
    Use electrical boxes, of course, where the plates will go. Put them at the same height as power outlets so they don't stand out. Use plates with connectors for a clean look (don't run the wire itself all the way to the speaker).
    Run extra wires wherever you think you might ever want speakers. 7.1 in the future? Might rearrange furniture, etc. You don't have to use all the wires.
    Label everything at both ends. Saves time down the road.
    Good luck
