Vintage 70s gear rated 60hz on 50hz power supply?
Hi there,
I'm hoping someone can help. I am interested in buying vintage Pioneer 70's reciever amps and there are plenty to choose from in the USA (E*ay) etc but they of course are all rated 120vAC 60hz.
I live in New Zealand where we are 230vAC 50Hz. Its easy to use an external step-down transformer but there will still be only 50hz. Does anyone know if this is a problem? is there enough iron in the main input transformers to run on 50Hz? Are the internal transformers simply a series/parallel primary winding arrangement where there are 2 say 110v windings in parallel for 110-120vAC supply and in series for 220-240vAC supplies? Would be good to know as there is heaps of this stuff in the USA and very little in NZ, could be worth all the shipping and additional effort.
Thanks!
