Would anyone have an idea on where to order a replacent tweater for a Beethoven concert grand tweeter?
07-01-2006, 01:39 PM
Florian
The manufacturer comes to mind.......
07-03-2006, 12:02 PM
topspeed
Yep, or contact Sumiko, their NA distributor (if you reside in The States).
07-03-2006, 01:37 PM
Woochifer
Could also contact the dealer where you purchased the unit. Even if the speaker's out of warranty, they should be able to address inquiries like this. Also, if your local Best Buy store has a Magnolia Home Theater add-on, you can also check with them since they are a Vienna Acoustics dealer.
